Background
Initial Conditions Setup
EFDC+ Explorer provides a user-friendly interface for configuring initial conditions (ICs) across all EFDC+ sub-models. Import data from common file formats, then edit, interpolate sparse datasets, apply values to user-specified regions, or aggregate dense data into model cells.
Water Column
Profile view of dissolved oxygen in EE.
Water Column
Set initial conditions as uniform constants or with horizontal and/or vertical variation, then visualize them in 2D plan or profile views for fast quality control.
Refine your setup with point-and-click cell editing or apply group edits across user-defined polygons for larger-scale adjustments.
Sediment Bed
Sediment bed core editor in EE.
Sediment Bed
Define constant or spatially varying ICs in seconds using EE’s powerful bed initialization tools.
The built-in sediment core editor lets you inspect grain size distribution plots and d50 values, create or remove cores, and automatically generate your model’s sediment bed.
