Background
Grid+
The Curvlinear Grid builder for EFDC+
Connect Grids
For complex riverine models, the model domain is often too intricate to represent accurately with a single grid. In such cases, you can create multiple grids and seamlessly connect them into one unified grid using Grid+.
Example of loading two grids and connecting them into one grid.
Build Modular Grids
When constructing complex grids, it is often necessary to build smaller sub-grids and assemble them in a modular fashion. Grid+ is designed to support this workflow by saving each sub-grid as a separate file, giving you full control to open, close, display, or hide individual grids as needed.
Split Grids
Grid+ also provides the ability to split existing grids into sections, enabling you to edit or refine specific areas before reassembling them into a complete grid.
