Release 12.3 Edge (250516)
May 2025
- Update on Bed Temperature Calculation: Incorporated longwave heat emission from the bed, accounting for heat transfer to the water column in wet cells and to the air in dry cells. This update enhances the realism of bed temperature in the model results, especially during wetting and drying.
- Updated the Array Output Option: Improved the output functionality to allow more efficient writing of additional variables for model diagnostics in the OUT file. Variables are now categorized into different groups, including Invariant, Hydrodynamic, Turbulence Quantities, Thermal Quantities, and Water Quality. Users can select the desired variable group based on their needs.
- Fixed Open Boundary Condition Concentrations with Outgoing Flows: Corrected the zero concentration value at open boundary cells with outgoing flows.
- Fixed Issue in Moving Qser Option: Corrected the identification of adjacent cells for migrating inflows.
- Fixed Point Source Mapping in the Water Quality Model: Resolved the issue of cell mapping for point source location when using the mass loading option in Water Quality.
- Fixed Internal Wave Model Issue (ISWAVE Option 3) in MPI Mode: Ensured that ramp-up forcing is not included when using ISWAVE option 3.
- Fixed Global Cell Mask in Fetch Length Calculation: Corrected the global values of UMASK and VMASK to properly account for the effects of masks on wave quantities.
- Fixed ICECOVER resetting: Corrected the ice cover on/off process to ensure its impact on the kinetics of Dissolved Oxygen (i.e., reaeration, loadings/demands ) in the water quality model.
- Fixed ammonia preference in Water Quality Module: Corrected the index of ammonia preference calculation of NH4 for accounting for different values from different algal classes.
- Fixed reading of SWAN input file: Corrected the reading “swan_grp.inp” file, which contains the wave parameters generated by SWAN for the external wave model.
Release 12.2 Edge (241022)
October 2024
- Add minimum depth for biota vertical migration
Description: A minimum water depth can be specified by users for biota vertical migration option Dynamic Velocity (Visser et al., 1997. As a result, the vertical migration of biota in one cell is only activated when the cell’s water depth is above that minimum depth. This addition prevents unrealistic results of biota concentration when the model uses the Dynamic Velocity option for biota vertical migration, especially in shallow water regions.
- Moving QSER inflow to adjacent cells
Description: With the moving QSER option, when the cell location of a flow boundary becomes dry, EFDC+ will look for a surrounding cell to determine if the flow can migrate. This process continues until the original cell location of the flow boundary is wet again, allowing water to flow in. The issue in EFDC+ 12.1 and previous versions is that the flow and the associated constituents at the new BC’s cells continue to migrate even when the BC’s location is reset to the original one. As a result, more sources of flow and, eventually, constituents will be added to the system than expected. In EFDC+ 12.2, the new BC’s cells are reset to zero whenever the original BC’s location allows the flow to migrate.
- Handling turbulence quantities at east open boundary cells
Description: The “L” index of east open boundary cells is incorrectly assigned, while EFDC+ handles the turbulence quantities for these cells. The issue causes incorrect values of turbulence quantities at east open boundary cells for models using GOTM for turbulence models. The “L” index of east open boundary cells was updated to the correct values in EFDC+ 12.2.
Release 12.1 Edge (240723)
July 2024
- COARE 3.6 Integration: COARE is one of the most frequently used algorithms in the air-sea interaction community to predict surface temperatures. It is designed to give estimates of the turbulent fluxes of sensible and latent heat and the stress from measurements of bulk variables such as water temperature, air pressure, and specific humidity. With the release of EEMS 12.1, the Environmental Fluid Dynamics Code Plus (EFDC+) will allow users to simulate these fluxes by incorporating the COARE subroutines. You can learn more about the implementation of this feature in our introductory blog post. In this more recent blog post, we have also demonstrated that the algorithm can be applied in freshwater bodies such as Lake Mendota.
- Vertical Layering Enhancements: A new vertical layering option following the Sigma-Zed (SGZ) approach has recently been added to EEMS. The new SGZ scheme allows the user to specify layer thickness in meters from the water surface. Itoffers significant flexibility in configuring the vertical layering system, complementing the existing options, including the original Sigma Stretch (SIG) and the current Sigma-Zed (SGZ). Learn more about these changes by reviewing this blog post or reading the Knowledge Base.
- Volatilization Option: When simulating chemical fate and transport, volatile chemicals at the air-water interface frequently off-gas from the water into the atmosphere. The Chemical Fate module in EEMS is designed to work primarily in conjunction with the Sediment module, as the toxic substances sorb to sediments. In cases where sediment data is sparse or missing altogether, using a dye class as a proxy for the dissolved chemicals is recommended. To help users more accurately simulate this case, a volatilization component has been added to the dye proxy. To learn more, read this blog post or the EFDC+ Theory Document.
- 3 Time Level Scheme Updates: A number of improvements have been made to the 3 Time Level (3TL) computational scheme. This numerical solution option is often more stable and faster than the 2 Time Level (2TL) scheme since it allows a larger computational time step. However, the 3TL scheme was not fully implemented in the original EFDC from Hamrick. DSI has refactored the code for the application of parallel computing using OMP-MPI. DSI has also fixed several bugs in the code so that 3TL has now become our favored solution option for hydrodynamic models.
- NetCDF Updates: EFDC+ has recently been integrated into studies as part of the Delft-Flood forecasting and Early Warning System (FEWS) platform. Delft-FEWS is open software using a modular framework to link big data to a local area or from other modeling systems. In this study, EFDC+ was required as one of the modules, and the NetCDF capabilities were required to be updated to the latest convention to allow seamless integration. Some of the improvements for EEMS 12.1 include:
• Upgraded NetCDF CF Conventions 1.4 to 1.11
• Upgraded to UGRID 1.0 Conventions
• Fixed standard names and units according to NetCDF CF Conventions 1.8 checker
Release 12.0 Edge (230925)
September 2023
- GOTM (General Ocean Turbulence Model)
- Navigation Locks
- Algae Vertical Migration
- Geographic Coordinates
- Macrophyte Hydrodynamic Feedback
- 3TL Timestep Adjustment
- MPI for 3TL
- Move Inflow Boundary
- Buoyancy with Potential Temperatures
Release 11.8 LTS (230825)
August 2023
- Partial cell masks to include full blocking with sills
- Issue of reading segment name file for hydrodynamic linkage file in WASP8
Release 11.7 LTS (230623)
June 2023
- Vegetation: EFDC+ vegetation drag option has historically used an implicit momentum approach for the external and internal model solution. However, this approach produced unrealistic velocities for multi-layer model when the vegetation only partially penetrated the water column. A new explicit approach has been added that handles both fully and partially penetrating vegetation in single or multiple layer configurations.
- Wind Waves: Coupled the EFDC+ wind wave approach to the SEDZLJ sediment transport module. Previously, the wind wave approach was only linked to the original sediment transport module. Improved the EE linkage of computed wave generated shear stresses and the display of wave parameters.
- Propwash: Implemented a new approach for specifying applied power to allow for forward and reverse thrust.
- Restart file generation: EFDC+ should allow the restart files to be generated at a specified interval or at the end of the run (EoR). However, the EoR option did not work properly. EFDC+ now will generate restart file at regular intervals and/or EoR.
- Wind Waves: Updated the wind wave module to use the average water depth along the fetch for each cell at each time step instead of average model domain water depth.
- Jet-Plume Boundary Conditions: Fixed the implementation of withdrawal/return flow option.
- MPI Implementation Bugs:
- High Frequency Model Output
- Jet-Plume boundary conditions
- Cell face masks (ISMASK > 1)
- For the two-time level solution, updated the wetting/drying process to prevent invalid adjustments to the water column constituent concentrations when a cell goes dry. This correction was already implemented for the three-time level solution.
Release 11.6 Edge (230220)
February 2023
- Cleaned legacy code when using manual array ALLOCATE and initialized to the function AllocateDSI to improve code readability and minimize the possibility of uninitialized variables.
- Clarified and updated treatment of ice time series and ice time series options. For the cases of ISICE = 1 or 2, the user specifies the time series of ice on/off. In legacy EFDC code, the ISICE = 2 option was for time series of ice thicknesses. However, EFDC has never used ice thickness in the calculations of ice impact; it only used ice on or ice off. Ice thickness was removed from the ISE time series. ISICE = 2 interpolates ice on/off flags to set the ice on/off state. If the ice flag is >= 0.5, then the ice flag is on; if the flag is < 0.5, then the ice flag is off.
- Lowered the minimum value used to prevent division by zero when concentrations are zero in the anti-diffusion option to eliminate impacts on the results.
- Additional code refactoring.
- Propeller momentum from a single propeller can be distributed across multiple cells if the propeller is larger than the cell size. However, in 11.5, propeller momentum was left “on” for some cells after the propeller was turned off. This bug has been corrected in 11.6.
- Fixed the EE linkage files to correctly save wave dissipation when using multiple MPI domains.
- Fixed bug with OpenMP multi-threading that produced slight differences in the results between single and multiple thread runs of the same model. Now there are no differences in EFDC+ results for single versus multi-threaded runs.
- Improved the single domain to multiple domain MPI runs when comparing model results. Small differences in results between a single domain run compared to multiple domain model runs still exist due to computer truncation error differences between different runs. However, these differences are generally very small when comparing time series for the same cell between different runs.
- Fixed bug that overwrote certain arrays read in the from the restart.inp file.
- Updated the reporting of propwash timing to the TIME.LOG file and screen.
- Corrected a bug when initializing bulk decay versus biodegradation.
- Fixed a bug when initializing a SEDZLJ bed from the SEDBED_HOT.SDF file.
Release 11.5 (221018) Edge / 11.5.2 Edge (230105)
October 2022 / January 2023
- Added “fast settling” sediment classes during propwash erosion events. The fast settling classes reflect the process of mass erosion due to a more turbulent and energetic flowfield in the propwash plume. These mass eroded sediments then behave differently in the water column than the original sediment classes, predominantly by reflecting a faster settling rate than the original sediment classes. The addition of the fast settling classes and the fate and transport of these sediments is dynamically handled by EFDC+. The fast settling classes are fully integrated into the toxics transport of EFDC+.
- Added two new open boundary condition types. A free tangential and a zero tangential anti-reflection boundary condition were added to improve the propagation of waves out of the model domain without reflecting off the open boundary.
- Improved the zero tangential and free tangential radiation boundary conditions previously in EFDC+ to handle non-zero average tidal levels.
- Added capability of macrophyte growth between layers and for the base of the macrophytes to be in any layer. Allows for floating macrophytes to start at the surface and drape down into the water column.
- Added more detail to the executable logging for the efdc+ output files
- Limit the withdrawal layers to only active layers. This check was needed because the Sigma-Zed vertical layering approach can use different numbers of layers per cell.
- Removed duplicate timing variables ISTL_ and IS2TL_ from all subroutines. These variables were available in the global module.
- Disabled horizontal eddy diffusivity and viscosity for large aspect ratio cells on the open boundary.
- Improved reporting of ice generation limitations when cells are shallow and/or dry.
- Added more checks for toxic bed initial conditions.
- Improve the performance of the cyclone wind field boundary condition option.
- Fixed issues with multiple toxics using multiple OpenMP threads. Now when using multiple threads or single threads, the toxic calculations are reproducible.
- Fixed water quality mass loading when using withdrawal flow conditions as the original mass loading approach for water quality state variables did not address withdrawals.
- Forced dry cells to be wet for point source loading inflows.
- Fixed a bug for converting groundwater inflow time series from input units to cubic meters per second.
- PSMLMULTIPLIER was added to the mass loading option to correct for 3TL solutions. Historically, the mass loading for 3TL was underestimating loads due to the trapezoidal correction. For 2TL solutions, the PSMLMULTIPLIER is = 1.0, but for 3TL solutions, PSMLMULTIPLIER is adjusted for the number of steps between the corrector step.
Release 11.4 Edge (220822)
August 2022
- Reverted gravity constant back to 10.3 version g = 9.81 m/s2 (In 11.2, the gravity constant was changed to 9.807 from 9.81 to represent a more “mid latitude” domain. This small change had a small impact on all models with density activated. For this reason, the change was reverted in 11.4 back to the 9.81 constant used in previous versions).
- Improved the application of the BC_EDGEFACTOR to address momentum flags for models with multiple boundary condition cells adjacent to each other. This will not impact models without a large number of adjacent BC cells.
- Ignored both evaporation and rainfall for the option IEVAP = 0
- Removed unnecessary variable arguments in numerous subroutines and functions
- Fixed bug that did not update ice temperatures when the ice cover fully melted. This will not have any impact on the model results.
Release 11.3 Edge (220712)
July 2022
- ChemFate partitioning options have been supplemented. This new feature allows the user to control partitioning on a cell-by-cell basis to better represent spatially varying site conditions. There are now two new files, PARTITIONB.INP and PARTITIONW.INP to allow for spatial varying of toxic partition coefficients in the sediment bed and water column.
- Added “fast settling” of cohesive classes that are eroded by propwash to the SEDZLJ sediment transport module. This was added to address different settling rates of material eroded by mass or bulk erosion (i.e. eroded chunks) of a cohesive bed. These larger chunks settle faster than the discrete particle erosion of a more uniform flow patterns.
- The “fast settling” approach has been fully integrated into the ChemFate module.
- Update to NetCDF for Lagrangian particle tracking module and added more variables. This now writes a separate file.
- Macrophyte and periphyton growth can now move between layers
- Macrohydro option to allow for impact of macrophyte growth on hydrodynamics
- SEDZLJ output frequency issue
- Zero HBED issue.
- Improved the treatment of momentum flags for open boundaries. Previously, open boundaries would disable the cell momentum for both the boundary cell and the adjacent cell if using the “zero tangential” option. Now only the open boundary cell momentum is disabled. If a model used open boundaries, the user may experience slight variations in model results during periods of higher velocities at the boundary.
- Several bugs fixed in ChemFate module including degradation and volatilization when using MPI.
- Improved bed temperature handling for shallow and dry cells when excessive solar radiation is transmitted through the water column. Ensured bed temperature initial conditions were within a realistic range (0 to 50 deg C) for models with shallow cell and/or wetting and drying activated that allow bed temperatures to be updated during the simulation, small differences in temperature, especially in the shallower cells, will be seen.
- Fixed bug for adding ChemFate using the jet/plume boundary condition. Previously, toxics were ignored in the plume calculations. Now the code correctly handles toxic discharges.
- Changed the code to use the internal TIMESEC global timing variable instead of integer iteration counts
- Fixed a bug when using hot starts with propwash and sediment transport turned on. Hot starts now work as expected
Release 11.2 Edge (220421)
April 2022
- Corrected the value of gravity in Jet/Plume
- Fixed issue of time series index for ground water source/sink interpolation
- Fixed issue of writing NetCDF file in certain models
- Improved the stablity of anti-reflection for open boundary
Release 11.1 Edge (220401)
April 2022
- WASP8 Linkage
- Tropical Cyclone Module
- NetCDF UGRID output
- Propwash Enhancements
- Jet/Plume Enhancements
- User defined wind drag option
Release 10.3.8 (211115) / 10.3.9 (220218)
November 2021 / February 2022
- Added high frequency output for multiple dye classes
- Added NetCDF output for multiple algae classes
- Corrected the implementation of O’Connor-Dobbins formula for the calculation of DO reaeration process in WQ models
Release 10.3.6 (211015) / 10.3.7 (211019)
October 2021
- Calculation of ice options 1, 2 to account for ice thickness and ice temperature
- Calculation of bed temperature and other temperature issues for legacy heat balance option
Release 10.3.5 (210825)
August 2021
- Arrays out for writing out more variables
- Vegetation drag
- Option for calculation of evaporation following Arifin et al 2016
- Changed propwash friction coefficient (c_f) approach to constant for submesh
- Functional double precision working for MPI
- Update to propwash bedload for original sedtran
- Using field file for bathymetry issue
- Toxics initial concentration issue
- Propwash bedload bugs in the original sedtran approach
Release 10.3.4 (210628)
June 2021
- Propwash for original sediment transport
- Display of propwash when blocked by masks
- Issue in the CSNDEQC function for Van Rijn’s approach
Release 10.3.3 (210608)
June 2021
- Reading input file for bed temperature, TEMB.INP.
- Full heat balance (legacy) in the temperature module.
- Issues in the propwash module.
Release 10.3.2 (210525)
May 2021
- Deactivate propwash mesh nodes blocked by dry land or grid masks
- Issue of sediment deposition to an empty bed
- Initial conditions for algae
- Reaeration process of DO in Water Quality module
- Several bugs in propwash module
Release 10.3.1 (210414)
April 2021
- Calculation of wave parameters for MPI models
- Activate different options for open boundary
- Time frequency of water surface and propwash
Release 10.3 (210315)
March 2021
- Propeller wash module
- Unlimited macrophyte/periphyton groups
- Unlimited zooplankton groups
- Oil wind shear
Release 10.2.4 (210205)
February 2021
- Output not written for internal wind-wave module output
- Issue related to using constant WQ loadings giving high values (1D River model)
- Initialized the QSUME3 variable in code
- Fetch not correctly calculated when using multiple domains for Internal Wind-waves module (will be fixed in EEMS10.3)
Release 10.2.3 (201230)
December 2020
- Issue of computing bedload fluxes for outflow for all non-cohesive sediment classes
- Issue when initializing sediment fluxes in sediment diagenesis
- Issue of ICAL parameter for Jet Plume model
- Scanning ISER.INP file when running on MPI model
- Writing WCOUT for shear stress from non-cohesive components
- HBED for SEDZLJ models and improved wet/dry
- Fixed issue of array size in some models
- Issue of high DO in 1D River model due point source loading not correctly updated in MPI version
Release 10.2.1 & 10.2.2 (200622)
June 2020
- Changed the unit of toxic bed in NetCDF to mg/m2
- Added latitude and longitude coordinates for volume oil tracking in NetCDF and changed WQFPIP by WQFPIPM
Release 10.2 (200527)
May 2020
New Features
- Implemented MPI – full parallel processing with EFDC+ on a single machine or on a cluster.
- Added Shellfish Farm module
- Added SEDZLJ Sediment and Toxics Modeling
Release 10.1.5 (200409)
April 2020
- Updates for hot starting SEDZLJ
- Updates NetCDF for LPT, Sediment, Toxics export
- Dividing by HBED = 0 in mod_efdcout
- Unterminated block and lack of defined temporary variables
- Toxic atmospheric deposition issue
- Issue for updating time variable wind and pressure field
- Issue related to culvert type 1 and 2
- Calculating air pressure gradient when using the pressure field
Release 10.1.4 (200316)
March 2020
- Wet and dry toxic deposition
- Fixed hydraulic structure: Culvert type 1,2
- Time variable winds and pressure field
Release 10.1.3 (200227)
February 2020
- Toxic dry deposition time
- Double precision exe for MLWC
- Bug for s_sedzlj missing EXIT for KBT
- SEDZLJ bedload
- NetCDF for Sediment Bed, Toxics, Wind, LPT, SedZLJ…
Release 10.1.2 (200114)
January 2020
Release 10.1.1 (191217)
December 2019
Release 10.1 (191112)
November 2019
New Features
- Added toxic atmospheric deposition
- Implemented face blocking
- Implemented new bottom shear approach for drag coefficients
- Updates to Time Varying Fields
- Implemented new STOPP approach, replaced STOP with STOPP
- Update to MLWC approach
- Redesigned AVCON (constant AV) approach
- Enable NetCDF for 64bits
- Updates to CALTBXY
- Updates to NQSMUL 5 & 6
- Changes to CALTBXY and CALHDMF
- Fixed bug with LPT 0 index for SUB3D/SVB3D
- Fixed constant AVO cases
- Fixed WQ open BC issue
- Fixed bugs in toxics when using hard bottom
- Fixed Issue with bedload exit and hardbottom
- Fixed fields for ASER and WSER
Release 10.0.1 (190812)
August 2019
- A number of minor updates to the Beta release.
Release 10.0.0 (190517 Beta)
May 2019
New Features
- Added use of spatially and temporally varying fields
- Implemented sediment transport updates
- Improved sediment bed initialization with more QC checking
- Provided user-defined cell-by-cell activation/deactivation of sediment transport for both SEDZLJ and Original sediment modules
- For SEDZLJ:
- Added equation-based erosion rate calculations (E = A*tau^n)
- Added ability for user-specified maximum erosion rates by class and layer
- Added user-defined sediment bed characteristics independent of SEDFLUME cores
- Improved bed shear calculation approach
- Provided user-defined dye classes
- The number of dye classes is now unlimited, with the ability for each class to have a unique set of properties including:
- 0 order decay or growth
- 1 order decay that is optionally temperature dependent
- Settling velocity
- Restructured the water column transport and vertical diffusion to reduce computational times
- Added spatially varying background vertical diffusivity (AVO)
- Added integrated reported flows in the EE linkage file EE_BC.OUT for better mass balance calculations in EE
- Corrected routines so that OMP results are exactly the same for all numbers of threads
- Made other code changes to improve model performance and accuracy
Release 8.5.0 (190520)
May 2019
- SEDZLJ bedload OMP bug
- Updates to the project file
- Negative sediment concentrations reporting
- WASP output
Release 8.4.4 (181128)
November 2018
New Features
- Added wind drag coefficient options that now include: Original Rel U/V, Hersbach, and COARE3.6 Simplified
- Improved the algorithm for computing wave-induced Stokes drift using SWAN outputs.
- Revised the LPT routine in EFDC+ so it now includes a slippage factor so particles do not adhere to walls
- Made a significant update to option 2 for groundwater interaction, with GWMAP and GWSER options
- WASP .hyd file not being generated.
Release 8.4.3 (180723)
July 2018
Minor New Features
- Improved the hydraulic structure to write time-series control states to linkage file
- Improved the LSQHARM calling logic for harmonics
Release 8.4.2 (180710)
July 2018
- 3TL solution with original EFDC SedTran
- Active-Parent Layering when parent layer completely erodes then deposition later
Release 8.4.1 (180524)
May 2018
- Added XYRATIO for large aspect cells
- Fixed division by zero issue of DIASED in Read C40 EFDC.input.f90
- Added the fixed SND EQ concentration to calsnd.f90
- Patches to restart options including restart usage of ISCI
Release 8.4 (180510)
May 2018
New Features
- Added time-variable and rule-based control of sluice gates
- Added rule-based control of the withdrawal/return boundary
- Added spatially variable AHD and AHO
- Added a momentum option for the flow boundary type
- Specified elevation – Free tangential open boundary condition
- Added a whole channel rating curve option
- Mass balance issues with 3TL solution and SEDZLJ
- Jet/Plume issues with using SGZ
- Withdrawal/Return momentum issue with bottom layer using SGZ
Release 8.3.1 (171229)
January 2018
New Features
- Added flat SGZ layering bypass to calebi.f90
- Added Spline interpolation to PSER data
- Clean up on toxics mass balance
- Updates to SEDZLJ and Toxics (mainly CBLTOX)
- SEDZLJ probability of deposition bug
Release 8.3.0 (171004)
October 2017
Major New Features
- Conserved mass balance in the SEDZLJ sediment sub-model
- Added toxics capability to the SEDZLJ sediment sub-model
- Added Volatilization and Biodegradation to toxics
- Enhanced the Sigma-Zed sub-model to support one vertical layer
- Modified the Sigma-Zed sub-model linkage files to exclude unused vertical layers
Minor New Features
- Updated continuation runs for enhanced Sigma-Zed and SEDZLJ models
- Added a growth factor for Dynamic Time Stepping
- RPEM output and linkage issues
Release 8.2.3 (170602)
June 2017
- Issue with wave calculations
- Update to SGZ metrics
- Fixed WNDWHT input bug
Release 8.2.2 (170303)
March 2017
- Issue with temperature spikes (requiring updates caluvw, calpuv2c, calpuv9c routines)
- Issue with dynamic time stepping
Release 8.2.2 (170217)
February 2017
Updates and Modifications
- Revised SGZ cell face metrics to better handle fluctuating WLs
- Updated SEDZLJ for erosion/deposition and bedload to correct mass balance
- Removed MORPHJ (note that this requires a change to the EFDC.INP file so all models need to be saved before running for this release)
- Open BC vertical velocities bug
- Changed calheat to treat dry cells
- Bug fixed for WNDWHT and rearranged indices
- Hydraulic structure issue
- Bug when ISTOPT(2) =0
- Changed the the order of the variables reading from C1A
Release 8.2.1
January 2017
- No bug fixes to EFDC+
Release 8.2.0 (161118)
November 2016
Major New Features
- Added netCDF Output from EFDC+
- Added Atmospheric Pressure Impacts on Hydrodynamics
- Added a new Temperature Sub-Model Heat Balance option
Release 8.1.3 (160923)
September 2016
- Updated #output location
- Fixed TFAST/TSLOW bug for Full Heat Balance
- Lagrangian Partical tracking issues in Sigma Zed
Release 8.1.2 (160825)
August 2016
- Changed the DryLoss summary
- Drifter going through hydraulic structure BCs
Release 8.1.1 (160809)
August 2016
- Added an option to fix particles to the bed after deposition
- Provided the ability for particles to not move with water depth
NOTE: Full deactivation and reinstallation required when updating to this version.
- 3TL issues (EFDCPlus)
Release 8.1.0 (160708)
July 2016
- Minor bug fixes
Release 8.0.3 (160603)
June 2016
- EE_SEZIJ.OUT and bugs from Yong Bok model
- Bug in SETBCS that caused the velocities to be reported as 0
- Reverted to Jacobian matrix to 073_OMP code
Release 8.0.2 (160509)
May 2016
- Issue with velocity not being output for some models
Release 8.0.1 (160404)
April 2016
- Corrected caltoxb.f90 issue
- Updated wet/dry issues with HKP/H1PK
- Updated caltran.f90 for the anti-diffusion (nuanced) approach
- Fixed some windwave issues when using SGZ
- Added LLAD/LKAD variables )
- Removed vegetation from open BC cells
Release 8.0.0 (160307)
March 2016
New Features
- Integrated Sigma Zed EFDC Model into EFDC+
- Added the OMP Model as part of EFDC+
- Enhanced hydraulic structures including culverts and bridges
- Added East-West connectors
For earlier releases, download the full change log: 2017_07_14 Updates to EE-EFDC (EE3 to EE8.2) (6299 downloads )
