What's New in Grid+ & CVLGrid
Release Grid+ 1.2 (250523)
May 2025
- Updated the write/read functionality for the coordinate system of a layer when saving/loading the project layout.
Release Grid+ 1.2 (241022)
October 2024
- Update Orthogonal Deviation in Grid+ for consistency with EE
- Update the application title when Grid+ is launched from EE
- Crash when turning off the grid layer in layer control
- Loading blue circle keeps blinking
- Extracting a grid with a polygon does not work correctly
- Exporting shapefile does not work
Release Grid+ 1.2 (240723)
July 2024
- Squeeze the grid by removing inactive grid nodes
- Refine the grid based on guide points from an adjacent grid
- Issues when generating Rectangular grid and Radial grid
- Corrected location issue when importing *.gpc grid
- Resolved missing triangular grid cells
Release Grid+ 1.0.1 (230717)
July 2023
- Updated orthogonalization of grid
- Added cell info when selecting a cell
- Add showing DEM Profile
- Updated Adjust Y scale for cross-section profile
- Loading overlay with shape file incorrectly positioned
- Opening the legacy project file with insufficient information caused crash
- Layers of an old project not cleared when opening a new project
- Visibility of the color bar issue
- Splitter Distance and Get Grid Properties issues caused crash
- Refinement factor in global settings were not being saved
- Turning off online background map made other layers turn off too
- Zoom to layer for DEM data file issue
- Plot empty when a cross-section elevation profile from DEM data was displayed
- When reset to new project the project was not saved
- Color ramp of orthogonal deviation on legend and grid did not match
Release Grid+ 1.0.0 (220822)
August 2022
- Failed to export KML due to wrong .NET Framework version
- Color ramp of Ortho deviation on legend and grid not matched
- Reset to new project
Release Grid+ 1.0 (220630)
June 2022
- Improved GUI
- Object-oriented selection
- Lat/Long coordinate system
- Online background map
- Generate grid from splines
- Orthogonalize grid
- Download online bathymetry data
- Integrated with EEMS
- Display multiple grid properties
- Shortcut keys use
Release CVLGrid1.1.1 (181128)
November 2018
Minor New Features
- Developed a new option for local refinement
Release CVLGrid1.1 (180510)
May 2018
New Features
- Added the ability to load alternative versions of KMZ and KML files
Release CVLGrid1.1 (180313)
March 2018
- Misspelling in the code that alerted virus checkers
Release CVLGrid1.1 (171009)
October 2017
Updates
- Ensured everything would be saved when using the Save Project functions
- Prioritized colors for new grids
- Enabled Copy Overlay to Splines followed by grid generation
- Added automatic creation of a new folder when saving to *.cvp file
- Many minor bug fixes
- Load DTM file issues
- RK/RM labels still kept after Reset Project
- Coarsen local
- Regularize Global
- Import corners(4)
- Export Spline after Fit to Polyline
- Move up/down grid layer
- Import SEAGRID, Ecomsed grid type
- Connect 2 grids
Release CVLGrid1.1 (161025)
October 2016
Updates- Added a rental license option
- Corrected spelling
Release CVLGrid1.1 (160926)
September 2016
Updates and Modifications- Added the ability to Load DTM File
- Added NS-EW connection
- Distance Measurement tool issue
- Number of grids = 0 after renaming the grid
- Crash when renaming “Grid layer” in Layer Control wtih Rename button
- Grid file not saved when Save Project
- “Add RK/RM labels” still kept after Reset Project
- Zoom to extents when loading a DTM file
- Copy Overlay to Spline in Layer Control
- Filename issue
- Zoom to Polylines Label issue
- Polyline Label issues
- Polyline Offset Function
Release CVLGrid1.1 (160911)
September 2016
Updates and Modifications- Updated grid editing
- Cleaned and formatted activation log
- Added file description in task manager
- Reset tool tips when project is reset
- Updated Display Option
- Updated Save Project
- Added licensing updates
- Spline export
- Grid Generate
- Project loading issue
- Global regularizing issues
- Grid connection issues
- Grid Select/Grid Delete,
- SEAGRID/ECOMSED import/export
- DXDY/LXLY grid import problem
- Delete cell by polygon
- Split grid issue
- Spline drawing
- Zoom extents issue
Release CVLGrid1.1 (160809)
August 2016
New Features
- Improved orthogonalization methodology and improved user controls.
- New orthogonalization options include use of Sorenson method and user-defined coefficients
- Loaded digital terrain models to use topographic data in developing grids
- Added Telescoping: the ability to create a distributed space between grid cells based on a user-defined distance weighting factor)
- Added Split Grid: ability to split a grid domain into two grid domains
- Imported and wrioe various new grid types, such as ECOMSED, SEAGRID, and CH3D
- Edited selected polyline and add RM/RK labels
- Added additional hotkeys for editing polylines
- Added the ability to copy polylines to other layers
- Improved and simplified layer controls
- Streamlined user interface and made it more user friendly.
